10-10-2020 02:53 AM
Is there a way to connect and disconnect VPN in Forticlient programmatically? I see that with Cisco VPN Client, there are options such as using the APIs they provide or executing connectivity ...
10-22-2021 01:48 AM - edited 10-22-2021 01:50 AM
Greetings,
I'm not certain how to do it programmatically with Cisco. But you may check this solution how to handle the disconnect, where a user wrote an expect script around the client: euer.krebsco.de
Paul Merritt, dissertation writer
02-07-2022 10:13 PM
Pretty much if you are working on building an Android VPN app, OpenVPN comes out as an option. Since OpenVPN has a lot of community support, you can easily build a VPN client for any platform. So I have created to an app in Java, using Android Studio.
03-02-2022 09:36 PM - edited 03-03-2022 07:37 PM
@ReedBellamy70042 wrote: WestPennPowerIs there a way to connect and disconnect VPN in Forticlient programmatically? I see that with Cisco VPN Client, there are options such as using the APIs they provide or executing connectivity ...
If you want to connect to a server behind a private VPN, from the outside, nothing you can do on you app can/will allow you to do connect. Unless you launch a VPN client and programmatically connect your network, to that VPN server, your java app will just sit there waiting for a socket on http connect.
04-05-2022 04:52 AM
A VPN client can be built using OpenVPN on any platform, since it is very community-based. Therefore, I have applied Android Studio to the Java app.
