thomas
Beginner
2951 part numbers required for 150 ephones, and 5 E1
I would like to run a Cisco Call Manager express using 150 phones connected to it.
Based on those requirements, I have figured out, it needs to be at least a Cisco 2951 , since it supports up to 150 ephones, And I aslo need 5 E1 cards.
I would like to confirm the part numbers to obtain this, I would like to have more memory than the standard 512M that the router has for default,how can I order it with the router? Or if it will come separately, what is the part number for it. I thought to install 2G of memory, but I understand there may be a recomendation for the amout of memory per ephone.
I have the two parts below, plus the questions below.
CISCO2951/K9
SL-29-UC-K9
Memory recommended for 150 phones?
Cards/modules required for voice 5 E1 ?
Thank you
Martin
1 REPLY 1
anchoudh
Engager
Hi Martin,
For Part number and order related queries you can open a case with Partner Helpline team they will be able to assist you.
Please use www.cisco.com/go/ph to do.
Hope it helps.
Anand
Pls rate helpful posts !!
Content for Community-Ad
Spotlight Awards 2021
