Highlighted
Beginner
3810 CCS Frame forwarding
Currently have 2 3810s with frame between. They are using CCS frame forwarding. I need to add 2 more 3810s, one at each end and still use the same frame connection. Any help on how to connect the 3810s at each end. Each 3810 will connect to the PBX, but my problem is how to forward the signaling from the new one through the current one.
Any help appreciated.
1 REPLY 1
Highlighted
Contributor
Re: 3810 CCS Frame forwarding
I am not sure if you are looking for the kind of toplogy and solution as depicted in this URL, but it is worth to take a look at it.
http://www.cisco.com/warp/public/788/pkt-voice-general/crs_cnct_fr_for.html#ver
