06-22-2004 01:24 PM - edited 03-15-2019 02:56 AM
I am trying to configure my 6608 T1 port as the network side. I have selected the Protocol Side to be Network but after the port registers I check the Device Configuration by clicking on the IP address of the port, and it states it is protocol - user even though Network is clearly configured. Can this port be configured as network side and if so what I am doing wrong?
Dave
06-23-2004 09:54 AM
you can do this as we are using 6608 T1 cards to connect between a Nortel PBX and our Call Manager environment.
What version of Call Manager are you using?
06-23-2004 09:58 AM
I've just checked our Call Manager cluster and I do see protocol Network when browsing the card using HTTP.
This could be a load issue or I have seen configuration correct in call Manager and not work.
Have you tried reloading the 6608 card or if you can't do that, have you tried reloading the port - not through Call Manager but through the 6500 series switch using CATOS commands.
06-30-2004 04:45 AM
TAC had me hard reset the card, not from Call Manager and this fixed the problem.
Thanks for the reply
Dave
