255
f-vanryckeghem
Beginner
7914 Installation problem
I try to install a 7914 on a CCM3.2.2a.
what are the configurations steps on the CCM ?
in the 7960 conf. menu. I tell that I use a 7914 moule using the default firmware. Apply the changes.
As soon as I do the apply, the direcory numbers zone in theconfiguration page prompt the following error message :
One or more errors occured while trying to get the Directory number information for this phone's lines. Try deleting and re-creating this device. If errors continue, it may be necessary to restore an earlier version of the configuration database.
(-2147467259)
And I only see horizontal lines on the 7914 module.
Help would be appreciated .... because I really don't see where to configure this beest ;-)
Frederic
1 ACCEPTED SOLUTION
kthorngr
Hi Frederic,
Symptom:
When trying to add an expansion module to an existing phone,
the following error occurs:
Directory Numbers
database. (-2147467259)
Condition:
Add a 7914 expansion module (and possibly, a VG248).
Workaround:
Create and execute the batch file on the Publisher.
Please copy the below lines into a batch file and execute on the publisher:
@echo off
@if "%4x" == "x" goto Usage
echo USE %2 >temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{53F89BAA-FF0A-4D3A-A885-B3006990D609}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 1, 2, 'Speed Dial 1', 1, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{93A6820A-191F-4A81-A033-10F2CA7C1596}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 2, 2, 'Speed Dial 2', 2, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{D24ABA1C-956C-412C-93AE-8EFFE4E19C14}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 3, 2, 'Speed Dial 3', 3, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{7EBBC1FD-31A8-4985-A30D-959D83C5C989}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 4, 2, 'Speed Dial 4', 4, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{B282E898-6305-413D-8F73-BA4604267856}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 5, 2, 'Speed Dial 5', 5, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{34D1104A-0EFE-4F18-87FD-6D301F5D7EB6}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 6, 2, 'Speed Dial 6', 6, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{AE52BBE9-833F-407D-BFE0-7052FFFDEF88}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 7, 2, 'Speed Dial 7', 7, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{194202DD-74C5-4C4A-92FC-65C1F19E0867}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 8, 2, 'Speed Dial 8', 8, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{93AFA4B1-C225-4593-B3EF-9D120E050508}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 9, 2, 'Speed Dial 9', 9, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{EB2F394B-B922-48DC-BAAE-ABCBA2595961}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 10, 2, 'Speed Dial 10', 10, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{141E5C5A-1F8A-4301-846C-668BB4FAE1BF}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 11, 2, 'Speed Dial 11', 11, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{E90346CB-0C23-49E5-B952-D2BFF871AAE5}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 12, 2, 'Speed Dial 12', 12, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{0941E1E0-9653-4A7E-AA1F-7A543A2D3A88}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 13, 2, 'Speed Dial 13', 13, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{81AAC2F3-18CE-4622-92E5-663242B6B924}', '{17E0D7EE-EF1B-4D0D-BBDB-91B7552A7A0E}', 14, 2, 'Speed Dial 14', 14, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{C9B88892-D177-4C52-8EC8-D59AA7AB2322}', '{DA9FDD74-4BA1-4213-A740-9AF2526E640A}', 1, 9, 'Line 1', 1, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{24758024-3052-4FB0-A0A6-9DA9D0FDBC6F}', '{DA9FDD74-4BA1-4213-A740-9AF2526E640A}', 2, 2, 'Speed Dial 1', 1, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{F2633698-3D21-4ADB-B66E-80724D14F924}', '{DA9FDD74-4BA1-4213-A740-9AF2526E640A}', 3, 2, 'Speed Dial 2', 2, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{413D829F-1C1A-4817-8705-130C3580F368}', '{DA9FDD74-4BA1-4213-A740-9AF2526E640A}', 4, 2, 'Speed Dial 3', 3, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{E6AE95C7-ADEC-43D1-887C-8ADBD1E466CF}', '{DA9FDD74-4BA1-4213-A740-9AF2526E640A}', 5, 2, 'Speed Dial 4', 4, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{8A7AD365-8267-4C4E-A3DD-B1D516DFA82A}', '{DA9FDD74-4BA1-4213-A740-9AF2526E640A}', 6, 2, 'Speed Dial 5', 5, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{0253B6FC-6BD0-4DA8-8786-9CF03B06F728}', '{DA9FDD74-4BA1-4213-A740-9AF2526E640A}', 7, 2, 'Speed Dial 6', 6, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{52878407-A7FD-4A2C-A681-F368A6000FAB}', '{DA9FDD74-4BA1-4213-A740-9AF2526E640A}', 8, 2, 'Speed Dial 7', 7, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{896BB2BF-46F9-4531-A06D-9E223365D1AD}', '{DA9FDD74-4BA1-4213-A740-9AF2526E640A}', 9, 2, 'Speed Dial 8', 8, 0, NULL, NULL) >>temp.sql
echo INSERT INTO PhoneButton (pkid, fkPhoneTemplate, buttonNum, tkFeature, label, paramN1, paramN2, paramT1, paramT2) VALUES ('{1A4875C4-8513-44EB-9374-88AC2F03C20C}', '{DA9FDD74-4BA1-4213-A740-9AF2526E640A}', 10, 2, 'Speed Dial 9', 9, 0, NULL, NULL) >>temp.sql
osql -S %1 -U %3 -P %4 -i temp.sql
del temp.sql
goto endd
:Usage
@echo Usage: InsertSidecarButtons "server" "database" "adminuser" "adminpw"
@echo Example: InsertSidecarButtons . CCM0300 sa ""
:endd
HTH,
Kev
6 REPLIES 6
gordon.hawkins
Explorer
you should probably upgrade to 3.2.2c and the latest ES patch..
-Gordon
kthorngr
Hi Frederic,
Symptom:
Directory Numbers
Condition:
Workaround:
@echo off
del temp.sql
goto endd
:Usage
:endd
HTH,
Kev
Thanks for your quick reply,
I did the insertion but nothing new in the button template and it still doesn't work.
Other info, I try do do it on a CCM 3.1.3a, and I get the same error.
And when I try to insert a new phone button template based on the 14-button extension-module, I always get an error
do you see other things I have done wrong ?
Frederic
Frederic,
Maybe the 7914 template is corrupt. You can try this procedure to see if it fixes your problem, but you will need to make a change in SQL.
1 - From Device > Phone Button Template copy the 7960 template to a new template. Rename this to something like "New 7914"
2 - Use SQL Enterprise Manager to open the PhoneTemplate Table within the CCM30x database that is being used
3 - Find the record for "New 7914" and set the numOfButtons field to 14 and the tkPhoneTemplateUsage to 1
4 - Go back to the Phone Button Template Configuration screen, reload that template and configure as needed
5 - Select the "New 7914" for the Expansion Module
Let me know if this helps.
Kev
Thanks a lot Kev, your previuous post resolves in fact my problem. But updated the wrong database ( CCM0301) and apparently I had to update CCM0302 one.
Other question .... wahta is teh difference between those two databases ?
Frederic
Sorry, should have been more clear. For Each CallManager upgrade the ccm030x database is updated as well. CCM0300 is the database installed on a clean server. The x is incremented by one for the new database. So, it looks like you have upgraded twice.
Glad you were able to fix your problem.
Kev
Create
Recognize Your Peers
Content for Community-Ad
