7985 not making calls
amadeusri
Hi, I have CME 4.1 and everything is up and running except for the two 7985 IP phones in the system. These phones are unable to make calls to select numbers, we just get a fast busy when the phone rings out. The phone numbers being called are on different service providers and mostly cell phones. However these numbers can be called from any of the 7961/7971 phones that are on the same system. Any ideas would be greatly appreciated, I'm currently at a wall here. Thank you in advance
eduardo_ojeda
Do you have MTP (Transcoding resources) set up into CME?
7985 sets try to initiate H.264 video calls by default on all calls. Under your voice-port configuration, you need to have the following:
voice-port x/x/x:23
bearer-cap speech
This should allow your 7985 to make calls to the PSTN.
Hope that helped, and if so, please rate post.
