8710 MTU Setting Remotely managed
shincanada
Beginner
Beginner
When I set my 8710 to be remotley managed by our conductor I am seeing 75% packet loss. Previous experince has showed that I need to change the MTU to 1300 as we are sending the traffic through DMVPN.
When the 8710 is in locally managed I can go to config --> default endpoint settings and change the MTU. This setting is not available when managed by a conductor. I have tried changing the MTU setting on the conductor but it doesn't help.
I have n open TAC case but thought someone might have done this already.
Manish Gogna
You may check the TPS API Guide ( page 31 ) for maxTransmitPacketSize
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/ts/api_guide/Cisco_TelePresence-Server-API-reference-4-2.pdf
Manish
- Do rate helpful posts -
Recognize Your Peers
