AAR with call forward and busy
vinhnguyen
I have two sites A and B setup with AAR. If A calls B and there is no bandwidth AAR works fine. However if user B setup call forward or busy to another phone AAR does not work at all. All I get is a quick beep on B and A get disconnected. Is this a bug or limitation of AAR?
CM is 3.3.4
thisisshanky
Level 11
Level 11
I will test this in lab here soon. The version I will test this on is 3.3.3. Are you CForwarding from B to A via the 4 digit extension ? Have you set AAR prefixes or external phone number masks on the phones properly ?
Sankar
PS: please remember to rate posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Yes I call from A to B, but on B phone I set the call forward and busy to reception. Phone B is onhook. I have set all the parameters correctly because phone B will work if I take out CFD and Call Busy.
Call phone B internally set callforward and busy to reception and check whether its working or not it can be an issue partition and Calling Search Space.
boquiason
Any luck on getting this tested on the labs?
