AIM module not in slot 0 like the E1 module
igolbery
Do you know if it exists a command when an AIM card is on the slot 2 of a 2691 XM and the E1 module is on slot 0.
Does it exist a command to tell the E1 card on slot 0 to use the DSP in slot 2.
Irene
igolbery
Can somebody give me is feed back.
Do I need to indicate to the E1 interface card in slot 0 how to join the AIM-30 in slot 2?
It doesn't matter what slot the AIM module is in, the DSP resources will be assigned to the E1 VWIC timeslots.
Make sure you add the commands -
network-clock-participate aim
network-clock-participate wic
network-clock-select 1 e1
This will ensure the AIM and the VWIC are using a common clock reference.
thanks
I will give you a feed back as soon as possible
Match exactly my need
Irene
