11-19-2001 12:01 PM - edited 03-12-2019 01:25 PM
I have an ata-186 and I was wondering if someone
already done this.
My ATA call the Cisco 1750 with FXS interface but
the 1750 doesn't call the ATA.
11-28-2001 02:21 PM
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
11-28-2001 02:31 PM
I support the ATA and the 1750 and it would take more info to figure this out. It can be done and it will work. But we would need to see the show run and capture debugs as well as look at the ATA config. If you can open a case so someone can capture that info.
11-28-2001 07:52 PM
Can you help to solve problem with ATA186 ?
It's strange we are running latest software, but unable to place 2 calls simoulteniously from the ATA186, even Codec is 0, Rec/Trans also equals 0.
Any suggestions ? ATA186 is registered with Cisco 3640 Gatekeeper and after that call is being terminated through AS5300. All codecs, like G723r53
are included in config on AS5300 side ...
Alex
