09-04-2018 04:03 AM - edited 03-13-2019 10:19 PM
we configured attedant console server;but ı coulnd't understand which version can ı install to my pc and how
09-04-2018 07:09 AM
The zip file has both, the server AND the client.
Did you read the CUACA documentation?
09-13-2018 04:41 AM - edited 09-13-2018 04:42 AM
09-14-2018 07:23 PM
Your one screen shot it looks like the product is not licnesed. Are you sure your lciensed.
what is the difference between your two screen shots.
09-14-2018 07:28 PM
You might be licensed fine.
You need to clicked the pulse sign and add your operator then login with it in the client it seems like your basically there.
09-17-2018 01:25 AM
09-21-2018 12:51 AM - edited 09-21-2018 12:52 AM
09-21-2018 12:51 AM
09-21-2018 10:30 AM
Hey if I am looking at this now your licensing is not right it says evaluation mode.
You only have resilency installed, and licensed correctly. You will need to fix.
09-22-2018 06:59 AM
How can i add the license.I have 3 license for this but i couldn't add.what is the correct license code
11-01-2018 06:04 AM
we couln't solve the problem how can I create the true license
11-02-2018 01:41 PM
