attedant console problem;
ozden ozdugun
we configured attedant console server;but ı coulnd't understand which version can ı install to my pc and how
11 Replies 11
Jaime Valencia
The zip file has both, the server AND the client.
Did you read the CUACA documentation?
java
if this helps, please rate
Hi ;
I create cuaca server and client but my server screen different.how can ı add operator account .
I added the attachment
Your one screen shot it looks like the product is not licnesed. Are you sure your lciensed.
what is the difference between your two screen shots.
You might be licensed fine.
You need to clicked the pulse sign and add your operator then login with it in the client it seems like your basically there.
Hi Gregory;
I added the license and restart the service but there is no change ,I will restart server
Hi Gregory
I added the license and restart the server but there is no change
Hi Gregory
Hey if I am looking at this now your licensing is not right it says evaluation mode.
You only have resilency installed, and licensed correctly. You will need to fix.
How can i add the license.I have 3 license for this but i couldn't add.what is the correct license code
we couln't solve the problem how can I create the true license
Buy one from cisco and follow the lac process documented in the documentation.
