Audio pairing issues
obiyomitobiloba
Beginner
Beginner
My Cisco is having issues detecting Microphones and Speakers though it is connected.
These has been affecting my meetings as my audience and I can't hear the host speak to us.
Kindly help to fix this as soon as possible.
Thank you
RachelGomez161999
Try this method-
Step 1: Check Bluetooth basics
Turn Bluetooth off and then on again. Learn how to turn Bluetooth on and off.
Confirm that your devices are paired and connected. Learn how to pair and connect via Bluetooth.
Restart your devices. Learn how to restart your Pixel phone or Nexus device.
Step 2: Troubleshoot by problem type
Can't pair with car
Step 1: Clear devices from your phone's memory
Open your phone's Settings app.
Tap Connected devices And then Previously connected devices. If you don't see "Previously connected devices," tap Bluetooth.
If you see devices you're not currently using, next to each device name, tap Settings And then Forget And then Forget device.
If you paired your phone and car before, next to your car's name, tap Settings And then Forget And then Forget device.
Step 2: Clear phones from your car's memory
To clear phones paired with your car, follow your car's manual.
Clear any phones you're not currently using.
If you paired your phone and car before, clear your phone.
Step 3: Refresh the device list, then pair
To learn whether to pair from your phone or car, check your car’s manual.
Pair from your phone
Check that your car is discoverable and ready to pair.
Tap Connected devices. If you see "Bluetooth," tap it.
Tap Pair new device And then your car's name.
Pair from your car
Keep this screen open.
On your car's list of devices, pick your phone's name.
If asked, check that the PINs shown on your phone and car's screens match.
Tap Allow access to your contacts and call history.
Tap Pair, Accept, or Confirm.
Greeting,
Rachel Gomez
Wayne DeNardi
Are you able to be a bit more specific about what device you have that you are having issues with?  Cisco is a brand name, with many different types of device and models.   Knowing specifically which device you have will enable us to provide you with a better idea of where to look to resolve your issue.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
