Auto-Attendant greetings and mail sounds issues.
alanbatres
Hi.
I have an issue with a Cisco Unity Connection, when the call is prompt to AA and play de greetings record it's sounds like a hhhhh.......eeeee.....llllll......oooooo wwwwww......eeeeee....llllllll.......ccccccccc......ooooo, the same situation is when a call its forwarded to voice mail.
I hope you can help me with this problem.
Thnks
Jaime Valencia
Look at CPU usage on the server, and try various call flows to make sure it's not network related.
java
if this helps, please rate
Ok i'm gonna to install RTMT to view cpu usage.
Thanks for the tip, i reply my result.
davrojas
Level 3
Level 3
Hello Alan,
Make sure you do not have any snapshots in place as they are not supported and will cause voice quality issues, also make sure your NTP is stable on the CUC server otherwise if you see several application logs complaining about it this might cause the issue.
デイビッド
