B-ACD on IOS getting strange sound
ilyaavers
Beginner
Beginner
Hi!
I'm trying to configure basic AA on IOS using Cisco's public TCL scripts. Here is my config:
application
service aa flash:/app-b-acd-aa-2.1.2.2.tcl
paramspace english index 0
param menu-timeout 1
param dial-by-extension-option 9
param handoff-string aa
paramspace english language en
param max-time-vm-retry 10
param aa-pilot 15672579882
param max-extension-length 4
paramspace english location flash:/
param second-greeting-time 30
param welcome-prompt _bacd_welcome.au
param number-of-hunt-groups 1
param call-retry-timer 10
param max-time-call-retry 10
param voice-mail 2077
param service-name call_queue
service queue flash:/app-b-acd-2.1.2.2.tcl
param queue-len 10
param aa-hunt1 7701
param queue-manager-debugs 0
param number-of-hunt-grps 1
dial-peer voice 1567258 voip
service aa
session protocol sipv2
incoming called-number 15672579882
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
All seems to be OK, but caller hears strange "scratch" sound instead of greeting. *.au files are OK, and playing correctly on computer.
You can check it out yourself - there is real number on dialpeer.
deb voip appl script:
*Jun 22 17:20:50.510: //4//TCL :/tcl_PutsObjCmd: TCL B-ACD: >>> B-ACD Service Running <<<
*Jun 22 17:21:04.358: //359//TCL :/tcl_PutsObjCmd:
proc init_perCallvars
*Jun 22 17:21:04.358: //359//TCL :/tcl_PutsObjCmd: TCL AA: ++ Playing Welcome Prompt and options menu ++
7 Replies 7
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
You cannot record .au files straight on the PC, router wants a special format not easy to prepare.
You can record them from any phone with a recorder script that I wrote:
http://pbevila.fastmail.fm/public/
excuse me, but this au files from Cisco distributed tar arhive with b-acd files.
Have you tried your recorded files before the cisco files ?
Now it works with Cisco's files, I'm played with configuration and router reloads...
The second q. is: how to get G729 encoded files? I need it in production environment instead of G711ulaw.
Googling does not gave me much interesting...
Why do you need g729 files ?
I have a g729 SIP PSTN connection and the ip-phones in few offices everywhere with g729 to avoid transconding and save bandwith.
The only place where I'm using g711 is one unity express module in central office.
You can use some software like cooledit. Note, "save as" is not enough, you must use the actual recoding function.
