Bad static going over Ireland PRI's
cpi
We are setting up our office in Dublin with voip. Everything seems to be configured properly. Only one problem, When we dial out bound from there gateway, there is dead air or really bad static when it connects. When you look at the q931 debug, you see the call connect, you also see the proper digits being sent. In bound dial on the same PRI's work with out a problem.. Any suggestions?
Thanks!
xepherys
Sounds like a telco issue to me.
yes it was... there was a L1 flag set to true of Meridian based pbx... it needed to be set to false.
Thank you
