Call Detail Reporting
dstubler
I am interested in getting call details out of Unified COmmunications Manager 6.1. When we installed the system we were told that we could use Crystal Reports to get the info out. Is this possible? Does anyone know how to connect to the DB? DOes anyone have a table list and field list?
Jaime Valencia
usual access is thru AXL, look at the data dictionary for DB layout
Programming Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_reference_guides_list.html
java
if this helps, please rate
java
bsieber39
you can export the CDR records into a sql database and run any reports against the database.
Hi william sieber,
I am having one doubt, how to export cdr details to SQL DB in real time with CCM 5.1
i'm not sure it is possible to do it continuously in real time. but you can go to the cdr analysis and reporting page and export files up to the current date/time and then use those in sql to find your data.
