call forwarding from a mobile phone to a cisco ios gateway does not work
agr
We have a german "anlagenanschluss" connected with 4 isdn voice bri channels to a cisco 3640 router. If a call to a mobile phone is forwarded to the router the call is disconnected.
deb isdn q931 and isdn error show the following output:
Apr 15 11:21:07.292: ISDN BR1/0 Q931: RX <- SETUP pd = 8 callref = 0x35
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Facility i = 0x91A113020200E102010F300A0201010A0101A1028100
- ETSI Supplementary Service, Invoke, Diverting leg 2
Calling Party Number i = 0x2183, 'xxxxxxx'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, 'yyyyyyy'
Plan:ISDN, Type:Subscriber(local)
High Layer Compat i = 0x9181
Apr 15 11:21:07.300: ISDN BR1/0 **ERROR**: host_incoming_call: Received a call with a bad bearer cap from <unknown> on B
Apr 15 11:21:11.420: ISDN BR1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x35
Cause i = 0x82E6333033 - Recovery on timer expiry
Apr 15 11:21:11.424: ISDN BR1/0 Q931: L3_Go: L3_GetUser_NLCB returned NULL cid 0x0 cr 0xB5 ev 0x45 ces 1 -- Message igno
red
Apr 15 11:21:11.424: ISDN BR1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xB5
Cause i = 0x80D1 - Invalid call reference value
the bearer cap is the same as with a simple incoming call (which works fine).
config of the isdn interface:
interface BRI1/1
no ip address
no logging event link-status
isdn switch-type basic-net3
isdn overlap-receiving T302 2000
isdn incoming-voice voice
isdn static-tei 0
maybe anyone has an idea about problem
thanks in advance
Andreas Gruber
6 Replies 6
asarkany
we had to use this command in all of our installation
isdn sending-complete
to solve forwarding problems.
Maybe this will help.
August
Thanks for your tip but I´m still getting the same error ...
Greets
Andreas Gruber
beab.schellst
You are not alone.
Same with a 3725. We get the same Output.
TAC said resolved with 12.2.15T2 but its all the same.
Did you find a Solution for your 3640, as TAC says it only applies to the 3700 Routers.
SS
You are definitely not alone.
We had the exactly same issue with the MRP200/300 on the ICS-7750.
The IOS gateway had problems as soon as it saw ISDN facilities.
We opened a TAC case and the output was a IOS that worked!
We are still waiting for the bug fix in the proper IOS releases - for the MRP we now have a "hand-knitted" software ...
The bug ID was CSCdz46826 , the case was closed last december.
Cheers,
Martin
That´s good to know,
today I tried also 12.2(15)T2 and the problem stays the same.
Hopefully it will be resolved in the next upcoming release because we don´t have many choices regarding the IOS must be a high 12.2 release...
Maybe if anyone of you knows anything new about this issue please post it, I will do the same.
Andreas
Hi Guys,
yesterday I tried the very new 12.3.1 release on the voice router and wonder how, the bug is fixed the call forwarding works.
I also tried it with 12.2.16 it also has worked but the calling number was not shown correctly. This also works with 12.3.1.
Greets
Andreas
