09-10-2003 08:03 PM - edited 03-13-2019 01:33 AM
Can some please give me a SQL query or way to find out what phones are associated with what pick up numbers.Or how many phones are associated with a particular pick up number.In table Numplan there is a field ikNumPlan_CallpickpUpGroup ho to query and get number from the value ?
Version 3.1
09-11-2003 06:46 PM
Below is the method i have used to obtain the information...
Dont ask me how the strings are derived.
select * from NumPlan where tkPatternUsage = 4
This will give a list of call pick up group numbers.
This list can be seen in CM web pages.
Each ext in a pickup group is associated with a ikNumPlan_CallPickUpGroup string like 0A4926D1-DBA7-46BD-A399-D6DBE92EB045
To obtain the DN associated with ikNumPlan_CallPickUpGroup
Select pkid from NumPlan dNOrpattern = 5007
The result = ikNumPlan_CallPickUpGroup which in this case is 0A4926D1-DBA7-46BD-A399-D6DBE92EB045
You could then perform a query that uses fields dNOrPattern and ikNumPlan_CallPickUpGroup to obtain
a list of phones associated with a pick up group number.
select dNOrPattern,ikNumPlan_CallPickUpGroup from NumPlan where dNorPattern < 4999
and ikNumPlan_CallPickUpGroup = "0A4926D1-DBA7-46BD-A399-D6DBE92EB045"
dNOrPattern ikNumPlan_CallPickUpGroup
4145 0A4926D1-DBA7-46BD-A399-D6DBE92EB045
4134 0A4926D1-DBA7-46BD-A399-D6DBE92EB045
4139 0A4926D1-DBA7-46BD-A399-D6DBE92EB045
Allan Wells
09-12-2003 06:58 AM
I'm using CCM 3.3(2). In this version, finding phones that belong to a Call Pickup Group is easy. From CCM just select Device>>>Phone, then in the Find Phone Where pull-down-menu select Call Pickup Group and then press the Find button.
