Can I place outbound calls using a VIC-4FXS/DID card?
lkrol
I have a 2821 with a VIC-4FXS/DID card...can I use this card for outbound calling if I have it setup for DID. I want to receive DID calls and place outbound calls on this card.
Running IOS 12.3(14)T5.
Thanks!
b.speltz
Level 4
Level 4
VIC-4FXS/DID cannot be used to connect to the PSTN. You will need an FXO for outbound. For inbound you can use this card in DID mode if PSTN provide the trunks.
For the documents on the card refer to the list.
http://www.cisco.com/en/US/products/hw/modules/ps3115/products_documentation_roadmap09186a00802c4a00.html
m-geisler
Hi lkrol,
seems you are out of luck!
" Serves only incoming calls from the PSTN"
Quote from:
http://www.cisco.com/c/en/us/products/collateral/routers/2600-series-multiservice-platforms/product_data_sheet09186a00800921e7.html
So it also seems to be a software limitation:
http://www.cisco.com/c/en/us/support/docs/voice/analog-signaling-e-m-did-fxs-fxo/24760-confg-vic-2did.html?referring_site=RE&pos=3&page=http://www.cisco.com/c/en/us/support/docs/routers/2600-series-multiservice-platforms/15268-vic-2did.html#did
Let me know if a newer version or better router changes anything.
On the other hand PRI/BRI don't seem to have this limitation!
Mike
