Can Wowza be a input stream for a vBrick DME?
ruben.montes
customer is recording using a propietary system and then sends it to Wowza, we want to use vBrick to do internal streaming? Can  I use Wowza as an inoput stream for a DME? What parameters do I need in order to configure it?
Thanks in advacne,
Ruben
Patrick Sparkman
Yes it is possible to stream from Wowza to the DME using Flash/RTSP Pull.  If you search in the DME Online Help for "Wowza" there are two examples, one that uses RTMP and the other for RTSP.
