09-25-2006 06:48 PM - edited 03-15-2019 04:33 AM
Hi All-
I have a 3845 gateway andI am trying to turn up an E&M / CAS T1. There are currently 6 other PRI T1s on this gateway that are fully functional, so I have good confidence in my MGCP setup. I have 24 ports defined in CCM and the gateway shows 24 voice ports DORM IDLE ILDE.
When I try to reset the T1 via CCM, all T1s in that gateway are reset (ouch!) This doesn't happen with my PRI T1s - are CAS different this way?
Any input, advice or assistance would be appreciated.
No alarms detected.
AIS State:Clear LOS State:Clear LOF State:Clear
controller T1 0/1/0
framing esf
linecode b8zs
ds0-group 0 timeslots 1-24 type e&m-wink-start
09-29-2006 12:06 PM
Check whether the slot is configured properly in CCM
10-03-2006 01:46 PM
Turns out that the first time a port is defined, you need to restart MGCP by doing a "No MGCP", "MGCP". Unless you do this, it seems that all ports on the gateway are reset when you attempt to reste the non-registered port.
