06-06-2012 01:12 AM - edited 03-13-2019 07:51 PM
hi everyone ,I have one problem as follow:
Site A ,Site C and Site B ,three sites. CCM CLUSTER at Site B. A,B and C connect each other use 1M bandwidth. but our customer want to site A phone call site C pass B when bandwidth insufficient. how to implement this requirement ?
I get stuck here .Please help me ! thanks a lot !
Solved! Go to Solution.
06-06-2012 01:48 AM
Only option to re route call when BW limitation is hit is through AAR. No other option available.
Ronak Patel
Rate all helpful posts by clicking stars below the answer.
06-06-2012 01:18 AM
I believe you can not do it by CUCM configuration. It is more of any routing the VOIP packets which has to taken care by routing protocol.
AAR will come in to play when CAC restrict the call due to low BW and AAR do not decide on which WAN path the VOIP packet goes.
Ronak patel
Rate helpful posts.
06-06-2012 01:28 AM
hi Ronak ,Thank you for your response. whether or not sla can resolve it ?
06-06-2012 01:40 AM
If BW limitation is hit and AAR is invoked, the CUCM will try to route the call using AAR configuration and if AAR is invoked the SLA will also not come in to play.
Ronak Patel
Rate helpful posts.
06-06-2012 01:44 AM
hi , I have not config AAR . if customer allow use AAR ,It's no problem.
06-06-2012 01:48 AM
Ronak Patel
06-06-2012 01:57 AM
hi Ronak, Thank you very much !
