CCM codec negotiation with GK
gofri
I need to config a codec negotiation between CCM and GK, I have 300K BW so I need to config 2x G.711 + 2x G.729 = 300K
At ccm I can config a region with only one codec.
Do anyone have a solution?
reg
Gal
nmilojevic
Use G.729 only for all 4 calls and have some spare BW.
Nikola
vmalhi
if you really want to do this....
- create two trunks to the gatekeeper, one in each Device Pool with correct region. (note: you don't need different locations)
- put the two trunks in a route group with the 711 trunk higher up in the order
- enable BRQ service parameter on CCM
- on gatekeeper- emulate bandwidth h323 cisco
- configure 288k on gatekeeper bandwdith
