CCM4 & Paging
alebrasseur
For one of our project setup on CallManager 3.3, we used a Bogen paging system.
I'd like to know if the paging feature is now part of the latest CM version ?
If not, can someone recommend any product ?
Thanks in advance !
SCOTT VOLL
Cisco has decided to let 3rd parties do broadcast paging. I personally recommend Berbee's Informacast. It is a Great system. Broadcast to everyone or as little as 1. Very configurable. Down to user rights also. Makes easy use of services also. I give it two thumbs up :-)
Scott
hi,
ccm has very little to do with any paging system and its model or make. as long as it has an fxs/fxo interface and can respond to proper seizure from the router or ccm it should be fine. it can be configured either on h.323 or mgcp. i have worked on several (including bogen) and they just work fine. let me know if u require any help on config issues.
rgds,
subhrojyoti
