CCM5 and transcoding
m.govorov
Hello
I have ccm 5 and outside branch works in the g729 codec i need configure transcoding but then i try configure transcoding like in the documnetation
i see only ccm 4.1
scc ccm 192.168.22.20 identifier 1 version but my ver sion is 5.1
so how configure transcoding for ccm 5
5 Replies 5
Marwan ALshawi
follow this link config
just make sure u have put the right ccm verion
and setting on both router and ccm similer if not identical :)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080334294.shtml
good luck
if helpful Rate
hello thank you for your response but in the voice gateway haven't ccm5 version
only 4.1
Hi, Upgrade your GW IOS to 12.4(15)T7
if you don't have it simply try dropping the version command, many times that does the trick without doing an IOS upgrade
java
if this helps, please rate
java
kinwai
i manage to use "version 4.1" with cucm 6.1
