ccme and h.323 voip trunks
bphelps
Level 2
Level 2
Is there any design problem with running a few voip h.323 trunks from ccme to an h.323 gateway? The gateway would be a 1760 with some fxo ports to the pstn.
Aaron Harrison
I shouldn't thinks so - just a matter of properly configuring your dial-peers etc...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Inbound/outbound calls work great, however, when I've got a call terminated and the voice path is pstn->1760gateway->2610ccme->ipphone when I transfer call to voicemail, it rings busy. If a call comes in on the second gateway and rolls to vm, it rings busy. Any sip dialpeer stuff that I should have?
This could be because VM requires G711, whereas G729 is default codec for voip dial-peers...
Try changing the dial-peers to :
codec g711ulaw
If this works, you have a couple of options:
1) If you have DSPs on your CME router spare, and have CME 3.2, I believe you can transcode for CUE sessions..
2) Set up a voice class codec with preference listed codecs, then apply it to your dial-peers:
Router#conf term
Router(config)#voice class codec 99
Router(config-class)#codec preference 1 g711ulaw
Router(config-class)#codec preference 2 g729br8
Router(config-class)#codec preference 3 g729r8
Router(config-class)#end
Router(config)#dial-peer voice 2000 voip
Router(config-dial-peer)#voice-class codec
Hope this helps...
Aaron
