Highlighted
jul Beginner
Beginner
CCME & Gatekeeper problem
Hi!
I use CCME. All works well!
After gateway registered on the gatekeeper as endpoint problems have begun.
Out call to RAS and to other gateways work but incoming call come only to ephone registered on GK.
2 REPLIES 2
Re: CCME & Gatekeeper problem
could you may explain your problem more preciesly. As far as I can see you have regular situation.
All cals through GK to ephones are sucessefull. Outgoing ephones calls through GK are sucessefull.
What does not work ?
Mladen
Highlighted
jul Beginner
Beginner
If router no reg on GK - all OK.
If router registered on GK, no incoming call from other gateways to any no-reg ephone or no-reg hunt-group. I have only one account ( 1 number) on GK assigned to 1 IpPhone (EFXS).
int Fast 0/0
h323-gateway voip interface
h323-gateway voip id GKid ipaddr 1.2.3.4
h323-gateway voip h323-id 191621
191621 - my account and my phone number from provider.
Out call work fine to RAS or other gateway.
