03-03-2004 08:23 AM - last edited on 03-25-2019 06:42 PM by ciscomoderator
Can someone point me to some documentation or an answer for converting the "dateTimeOrigination" entry in the CDR database into a real Date/Time format. The timestamps are in UTC format and we would like to make the conversion within an Excel spreadsheet.
03-03-2004 10:41 AM
from
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d71c5.shtml
Understanding the Date Format in the CDR Database
To select all calls after a certain date, you need to convert the date you want into a value in universal time and in seconds since January 1st, 1970.
For example, 973995954 translates to 11/12/00 2:25 AM. Use the following procedure to decipher the time stamp.
Go to Microsoft Excel.
In cell A1 type the number that is found in the last record for dateTimeOrigination.
In cell A2, paste the formula =A1/86400+DATE(1970,1,1).
Right-click on cell A2 and select format cells.
Under the Number tab select Time where the format is 3/14/98 130 PM.
The result is the actual time in readable format.
Use the following procedure to convert the day you want into the date.
Enter the date in cell B2 in the format MM/DD/YYYY 00:00 AM.
In Cell A enter the formula =(B2-DATE(1970,1,1))*86400.
Right-click on cell B1 and select format cells.
Under the Number tab, select Number.
This number is the universal time in seconds that is used in the formula.
03-04-2004 08:13 AM
These fomulas don't work.
Here is an example-
My perl script output-
C:\perlprogs>perl tconvert.pl 1074732166
Wed Jan 21 19:42:46 2004
The excel formula result for 1074732166-
1/22/04 12:42 AM
Date and time from a CDR search matches the perl script.
Here is the perl script I use-
#! c:\perl\bin\perl
# convert single integer on command line (assumed to be standard
# unix "seconds since 1/1/70" time) to local date.
require "ctime.pl";
if ($#ARGV >= 0) {
$time = shift(@ARGV);
else {
die "Usage: num2date number\n";
print &ctime($time);
06-20-2013 06:42 AM
In ISO format:
use POSIX qw( strftime );
use File::stat;
$fecha = strftime('%Y-%m-%d %H:%M:%S', localtime( $PRE_fecha ) );
07-13-2018 07:46 AM
07-30-2014 11:25 AM
=(A1 / 86400) + 25569
Format the result cell for date/time, the result will be in GMT time (A1 is the cell with the epoch number). For other time zones: =((A1 +/- time zone adjustment) / 86400) + 25569.It gives you GMT time. If you would like to convert MST (in our case) time please use the below formula in excel.
=A2-TIME(7,0,0)
03-07-2024 07:48 PM
Dear Prabaharan,
I need to convert it to IST. Could you please tell me the formula for this
03-07-2024 09:55 PM
Isn’t that just to subtract 5.5 hours? You have the formula in @PRABAHARAN C answer, you’ll just need to make the needed adjustments to it.
