Cer Maximum Elin
t.dhaliwal
How many maximum Elin can you have with the latest CER?
Steven Smith
Level 7
Level 7
Do you mean ELIN's total or ELIN's per ERL?
I meant how many ELIN's total on the system you can configure.
According to Cisco documentation, there is no limit on how many ERLs/ELINs you can build on the CER server. There used to be one in the earlier versions because each ELIN needed its own Route Pattern to be configured on the Call Manager, but they got this fixed with the "Enable Calling Party Number Modification" parameter. See the following URL:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps842/products_administration_guide_chapter09186a008023659c.html#wp1093007
See the paragraph under the heading "Advantages of Using Call Party Modification".
Joseph
