Need to update a couple fields on our LDAP config in CallManager, so what i was planning to do was to delete the current directory config, and re-create it and update the couple field mappings (middle name to middle initial, URI from MSRTC to mail).
I'm wondering if anyone has done something similar and if you've come across any issues with information for the end-users getting hosed up in the process (PIN, groups, etc.).
CallManager version is 9.1.2
