02-18-2005 05:59 AM - edited 03-15-2019 03:16 AM
I have Cisco 3550 and 6513 switches on my network. We are testing VoIP with Avaya4620 phones. I configured the 6513s with voice vlan, configured the 3550 for voice as well. Here is one of the ports configuration;
interface FastEthernet0/38
switchport trunk native vlan 18
switchport mode trunk
switchport voice vlan 818
spanning-tree portfast
spanning-tree bpduguard enable
And here is one of the 6513's configuration;
ip dhcp pool VLAN818-pool
network 10.68.0.0 255.255.255.0
default-router 10.68.0.1
netbios-name-server 161.195.161.117 161.195.161.116
netbios-node-type h-node
dns-server 161.195.161.39 161.195.161.211
domain-name fss.aramark.com
option 176 ip 161.195.160.163
interface Vlan818
ip address 10.68.0.3 255.255.255.0
no ip redirects
ip route-cache flow
standby ip 10.68.0.1
standby preempt
Vlan 18 is the data vlan, we need to plug the PC into the phone. My problem is the phone never gets the IP address from the 6513. If I configure the phone with the VLAN ID 818, the voice vlan, then the phone gets the right gateway, and the subnet mask, but not the IP address. On the phone there are options such as CallSRV, FileSrv, some ports, etc. It seems like the phone cannot get to the tftp server since it never gets an IP address. Could anybody tell me if the Cisco switch configurations are right?
Solved! Go to Solution.
03-01-2005 08:35 AM
glad it worked. The tftp is used mainly to upgrade the phone software aka firmware but there is a 46xxsettigns file that can be used to tweek the phone.Extention are assigned via avaya call server or as you did via extention mobility.
MUTE LOGOFF# or MUTE LOGON#
so you place the newest phone firmware and the 46xxsettings file in the tftp directory.
Newest phone firmware:
settings file:
02-25-2005 07:41 AM
Did you check any debug commands that can be given to monitor DHCP request and reply.
debug dhcp details.
or show dhcp server.
02-27-2005 06:15 AM
The interesting part is that the phone gets an IP address for about two seconds. If I do sh ip dhcp bind I can see the IP address of the phone. At that point it wants to connect to the tftp server, but for some reason I can no longer ping the phone abd the connection to the tftp server fails. Then the phone goes throu the same cycle again and grabs another address and try to connect to the tftp server, etc. If you wait long enough it will consume the class C address range. I can ping the tftp server. The Avaya phone is looking for option 176, the Cisco phone is looking for option 150 in the dhcp assighment.
02-27-2005 10:34 AM
A couple things:
1) You need TWO option 176 settings one in data vlan scope with only "L2Q=1,L2QVLAN=818" and one in the voice vlan scope "MCIPADD=#.#.#.#,MCPORT=1719,TFTPSRVR=#.#.#.#"
The first causes the avaya phone to go to your voice vlan and release it's address from data vlan. Once on voice vlan it grabs address and clan,tftp etc info.
-MCIPADD is the IP address of the C-LAN
-MCPORT is the UDP port that is used for telephone registration
-TFTPSRVR is the TFTP server that the telephone uses to look for firmware and configuration
upgrades
L2Q is 802.1Q. 1 is on, 0 is off
L2QVLAN is the VLAN that the telephone uses. Vlan ID 0 is a special vlan ID that tells the next
Layer 2 switch to replace the 0 tag with the native vlan ID on that ingress port.
In dhcp data scope option 176 only with this:
L2Q=1,L2QVLAN=818
In dhcp voice scope option 176 with this:
2) Disable option 150, I've seen is cause issues with avaya phones.
3) read these documents:(will clarify everything)
4) you might want to consider using a windows or linux box for dhcp.
02-27-2005 11:56 AM
Oh i forget one other thing, 176 is a ascii option and needs to be configured like this :
Data Vlan
option 176 ascii"L2Q=1,L2QVLAN=818"
Voice vlan
option 176 ascii"MCIPADD=x.x.x.x,MCPORT=1719,TFTPSRVR=x.x.x.x"
**and your tftp script file (46xxsettings) should not include any of the above in it ***
Also, There is a way to use a http/https server instead of tftp with Avaya phone firmware 2.1.3.
HTTPSRVR=x.x.x.x,HTTPPORT=80. Ask your Avaya SE on config notes for this.
02-27-2005 01:50 PM
I'll try your suggestion first thing Monday morning and let you know the result.
03-01-2005 07:58 AM
It worked! The phone gets an IP address, now I can ping the phone. I just found out that we do not have a tftp server. Since we do not have a tftp server I neede to assing an extention to the phone manually. After that the phone set itself up fine. If I set a tftp up do you know what needs to be in the file that comes from the tftp server? The issue now is that the phone does not have a dial tone and it does not ring, but I think that is the Avaya Callmanager's configuration issue.
Thank you for your help.
03-01-2005 08:35 AM
settings file:
03-01-2005 09:55 AM
03-20-2007 12:25 PM
Kleo I have The same problem with the 9600 avaya phones.
I made the procedure and apply your recomendations, they work very good.
You save me , thanks a lot
