取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
Cisco 8845 phones with CUCM 10.5.1.10000-7
AGLicenses
Do I need to up grade Call Manager to 10.2 for the cisco 8845 phones to work?
2 条回复2
Rob Huffman
Hi there,
Yes, you would need to upgrade to 10.5(2) to add support for the 8845 as shown below;
Call-Control Support
Cisco Unified Communications Manager
  8.5.1 (non-secured mode only)
  8.6.2
  9.1.2
  10.5.2
  11.0 and later
Cisco Unified Communications Manager Express
(Unified CME)
  Planned to be supported 11.5
From;
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/datasheet-c78-734730.html
Cheers!
Rob
Jaime Valencia
You'll also need to either install a DevPack, or upgrade to the latest 10.5(2)SU which has native support for it, you probably want to just upgrade to the latest SU and avoid the DevPack
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix_chapter_00.html#CMDP_RF_C8E075E1_00
java
if this helps, please rate
