Cisco Cube and Genesys CX - Setup TLS connection
MiB
Hi all,
I'm trying to configure a trunk between my Cisco CUBES(ISR4431) to Genesys Cloud for a new implementation
Has anybody made this challange ?
It works with SIP/RTP and SIP/SRTP but when i switch to SIP with TLS it fails.
TLS Handshake between Cube an Genesys is completed and cube sents a invite to Genesys but no response to this, TLS Connection will be closed from Genesys side. Otherwise, call from Genesys cloud, i can see TLS Handshake in pcap at my cube but i dont get data from there after tls is completed.
Unfortunately, the genesys colleagues have almost no information and access to the system as it is a cloud service.
(Their service partner looks like they don't have a clue either)
I run 17.06.03a on cube, TLS to CUCM works fine
may someone has implemented this successfully
17 Replies 17
no worries, thank you, thought it might need some special setup like MS teams. Will figure it out as I go a long, have had a connection to genesys on-prem edges so could be the same setup then just pointing to the cloud.
Best Regards
alisha_rascon01
Setting up a TLS (Transport Layer Security) connection between Cisco Cube and Genesys CX involves configuring both systems to use secure communication. Here's a general guide on how you can achieve this:
Cisco Cube TLS Configuration:
1. Generate Certificates:
- Obtain or generate X.509 certificates for the Cisco Cube. You may use a certificate authority (CA) to sign these certificates.
2. Upload Certificates to Cisco Cube:
- Upload the generated certificates (public and private key) to the Cisco Cube.
- Use the following commands on the Cisco Cube:
voice service voip
tls srtp
certificate <certificate_name> [password <password>]
3. Configure SIP TLS on Cisco Cube:
- Enable SIP TLS on the Cisco Cube using the following commands:
voice service voip
sip
bind control source-interface <interface_name>
tls bind source-interface <interface_name>
4. Define SIP Profile:
- Define a SIP profile that uses TLS. Example:
voice class sip-profiles 1
request ANY sip-header Via modify "<sip_profile_name>"
5. Apply SIP Profile:
- Apply the SIP profile to your voice service configuration:
voice service voip
sip
sip-profiles 1
eljose_lol
Hello MIB, Trying to set up TLS between CUBE and Genesys, could you please sharing the configuration that you used in CUBE ?
