Walkthrough Wednesdays
1681
Rohit Khajuria
Beginner
Cisco IP Phone 8861 Configuration Guide
Can someone please guide me through Cisco IP Phone 8861 configuration guide ?
Regards and Thanks in advance !!!
9 REPLIES 9
Leo Laohoo
VIP Community Legend
Are you using Enterprise-based firmware or 3PCC?
I dont get what u said....but this is the firmware we are using in our environment... sip88xx.12-0-1SR1-1
Is there a Cisco CallManager in the network?
Yes, version 11.x
Jaime Valencia
Hall of Fame Cisco Employee
What configuration guide are you following?
and what problem do you have?
java
if this helps, please rate
I am getting error as Customisation Pending or Failed.
Also, the phone is displaying Phone not registered.
Also, I could not find any specific configuration guide for the same.
Jaime Valencia
You can just follow the 8800 series configuration guide, the basic configuration for pretty much all devices in CUCM is the same, add it under device and configure the mandatory fields, and any other fields you'd need. Make sure the device can reach the CUCM server and the TFTP server.
java
I checked the configuration on the phone and all the required configuration is correct like DHCP server, Domain Name, etc. But I could not find any such option for TFTP in the phone.
Settings --> Admin Settings --> Network SetUp --> Ethernet SetUp -->IPV4 SetUp
DHCP - On
DHCP Address Released -- No
Enable VLAN - On
Resync DHCP Option to Use -- 150
Please let me know if anything else needs to be taken care of.
Content for Community-Ad
Spotlight Awards 2021
