10-17-2017 11:21 PM - edited 03-13-2019 10:02 PM
Hello, I have problem in my network , all downloads get hang on bytes, whenever we try to download file it downloads with normal speed but then it drops to 0 byte/s and hangs there. on every computer in our lan .
boot-start-marker
boot-end-marker
logging buffered 4096
logging console critical
aaa new-model
aaa session-id common
memory-size iomem 10
clock timezone Tbilisi 4 0
no ip source-route
ip dhcp bootp ignore
ip dhcp excluded-address x
ip dhcp pool machines
network x
default-router x
dns-server x
ip cef
no ip bootp server
no ip domain lookup
ip domain name x
ip name-server x
ip name-server x
no ipv6 cef
no spanning-tree vlan 1
no spanning-tree vlan 10
vtp mode transparent
vlan 10
name LAN
ip tcp synwait-time 5
class-map match-any blocktorrent
match protocol bittorrent
match protocol kazaa2
match protocol edonkey
match protocol fasttrack
match protocol gnutella
policy-map blocktorrent
class blocktorrent
drop
crypto ipsec transform-set ESP-3DES esp-3des esp-sha-hmac
crypto ipsec transform-set transform-method-1 esp-3des esp-sha-hmac
crypto ipsec profile x
set transform-set ESP-3DES
set transform-set transform-method-1
interface Tunnel10
x
ip address x
ip mtu 1446
ip virtual-reassembly in
ip tcp adjust-mss 1360
tunnel source x
tunnel mode ipsec ipv4
tunnel destination x
tunnel protection ipsec profile x
interface Tunnel20
x
ip address x
ip mtu 1446
tunnel source x
interface Tunnel30
x
ip address x x
ip mtu 1446
tunnel source x
interface Tunnel40
x
ip address x x
ip mtu 1446
tunnel source x
interface Tunnel50
x
ip address x
ip mtu 1446
tunnel source x
interface Tunnel60
x
ip address x x
ip mtu 1446
tunnel source x
interface Tunnel80
x
ip address x x
ip mtu 1400
tunnel source x
interface Tunnel190
x
ip address x x
ip mtu 1446
tunnel source x
tunnel protection ipsec profile xs
interface FastEthernet0
description ### LAN ###
switchport access vlan 10
no ip address
load-interval 30
spanning-tree portfast
interface FastEthernet1
no ip address
load-interval 30
interface FastEthernet2
no ip address
load-interval 30
interface FastEthernet3
no ip address
load-interval 30
interface FastEthernet4
description ISP
ip address x x
ip nat outside
load-interval 30
duplex auto
speed auto
no cdp enable
interface Virtual-Template2 type tunnel
ip unnumbered Vlan10
tunnel protection ipsec profile HEAD
interface Virtual-Template50 type tunnel
tunnel protection ipsec profile profile-method-1
interface Vlan1
no ip address
shutdown
interface Vlan10
description ### LOCAL AREA NETWORK ###
ip address x x
ip nat inside
service-policy input blocktorrent
ip local pool x
ip local pool x
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list NAT interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 ISP
ip route x
ip route x
ip route x
ip route x
ip route xI
ip route x
ip route x
ip route x
ip access-list standard MGMT
permit x
permit x
permit x
permit x
permit x
deny any log
ip access-list extended x
permit ip x x
permit ip x x
ip access-list extended NAT
permit ip x any
access-list 127 permit ip x host x
access-list 128 permit ip host x host x
control-plane
alias exec c conf t
alias exec ss show run int
alias exec s show ip int brie | e una
alias exec r show ip route | be Gate
line con 0
logging synchronous
line aux 0
line vty 0 4
exec-timeout 60 0
logging synchronous
transport input telnet ssh
scheduler interval 500
ntp server x
end
10-19-2017 07:54 AM
Kuchuxa,
Did you try removing the policy from VLAN 10 to see if that is the culprit?
interface Vlan10 no service-policy input blocktorrent
10-20-2017 12:48 AM
I tried it but its same, no change
