Cisco VoIP Gateway Configuration with Genesys
cjnelson1
I would be interested in seeing the configuration posted in a previous thread outlining a successful Cisco to Genesys implementation.
I am setting up a Cisco ip2ip gateway to work in conjunction with the Genesys auto answer feature. While I am slightly baffled at what is happening there, seeing a standardized config would help considerably. I am sure there is some setting that would greatly aid in the implementation. I would be happy to post my config if it would help.
Attached are the sip messages related to the auto answer.
It appears as if it sends a notify to the Cisco device, but the Cisco responds with SIP/2.0 489 Bad Event - Malformed/Unsupported Event.
Is there anything that can be done to support the subscribe / notify that is being received from the Genesys?
gmarogi
Level 5
Level 5
489 is indeed a response to a subscription request or notification containing an Event package that is unknown or not supported. It's also used to reject subscription requests that do not specify an Event package at all.
