Greetings,
We have developed some internal caching apps leveraging the use of the Cisco-provided devicelistx.asp. We have used the tool to evaluate and verify environment changes before/after a change control.
Everything works fine, except we have found that the devicelistx.asp performs poorly with large records.
Doing some analysis of the performance we have isolated the "problem" to the getRISInfo() function in the ASP. Specifically, we have found that it takes approximately 46 milliseconds per record to retrieve the status. This sounds pretty quick until you process 13,000+ records.
My question is this:
The getRISInfo()function is using the ActiveXComponent: RISX.DeviceInfoX with a method (.SelectDeviceByDeviceName), is there another method for RISX that would allow me to grab all registered (status==1) devices?
