CME 7.0 - Extension Mobility for 7975
ionutionescu
I'm experiencing an issue with Extension Mobility on a CME 7.0 environment with the 7975 model.
When i press the Services button on the phone and I select Extension Mobility, the following error appears: "Not enabled on this phone!". The ephone config is the same as the config for other models with EM enabled (7911, 7965, etc) - the voice logout profile and ephone template work just fine for other phones. The 7975 is the only model with this problem. Any ideas pls?
vmoopeung
Level 5
Level 5
Have you issued the create cnf and reset the phone since the extension mobility configuration?
Yes I did - with no notable results.
I really don't know what to try next... I changed the phone with another one (same model), I changed the firmware (3 different versions) - nothing works.
As soon as I change the mac address from the ephone configuration with the mac of another model (i.e. 7965), everything works fine...
Hey All!!
I can tell you also that I did a factory reset to all IP phones undergoing the issue and the problem still persist.
Only ONE thing will do the job: RELOAD the CME router
Cheers!!
