09-11-2003 09:25 PM - edited 03-13-2019 01:34 AM
dell workstation
win2000 server,
win-os-upgrade-2000-2-5
win-os-upgrade-2000-2-5-sr1
when i install the cmm 3.3,
it appears:
service pack 3 is not installed.you must have service pack 3 installed in order to install cisco callmanager
any idea?
09-17-2003 03:02 AM
Any answer to this? I have the same problem with a MCS7825.
09-17-2003 03:25 AM
I just found in release notes for 2000-2-5 out that there is a bug......
· Cisco CallManager version 3.3(2) cannot be installed after running this upgrade. CallManager 3.3(2) does a pre-installation check for Windows 2000 Service Pack 3 that will fail once Service Pack 4 is installed. After you have installed CallManager 3.3(2), it is safe to run this upgrade (CSCeb29886).
If you try to view the bug it doesn't show it.
Quickest way is to flatten the server and start again - but this time install CM3.2 before upgrading the OS.
09-17-2003 06:17 AM
i can't run 3.3(2) installation on win2k (os 2000-2-4) too.
09-18-2003 08:12 PM
Yes, the Service Pack 3 for the Windows 2000.
Win-os-upgrade-2000.2.5 installs Windows 2000 Service Pack 4. Read the release notes for win-os-upgrade-2000.2.5. You cannot install any version of CCM v3.3.x with win-os-upgrade-2000.2.5 installed.
Before CCM v3.3.x installs, it checks to see if Windows 2000 Service Pack 3 and ONLY is installed.
This happened to me. Your only choice is to start from scratch and load win-os-upgrade-2000.2.4, CCM v3.3.x, then load win-os-upgrade-2000-2.5 and win-os-upgrade-2000-2-5-sr1.
