CMS 2.3 disable coSpace connection methods
robertb
I would like to disable the connect by phone feature in the guest landing page after entering a coSpace via a Call ID.
I know this can be done on a global level by disabling it on user profiles and associating it on a global level. When i sign in through the new meeting App, 1.10 it does not show, only WebRTC app(via chrome) is giving me grief.
Anyone played around with this?
Many Thanks !
5 Replies 5
Patrick Sparkman
I've noticed the same thing, tried it myself.  By setting canMakePhoneCalls under /userProfiles, it will hide the "Use my phone" option under Join Meeting for CMA, but not for the WebRTC client. Recommend you open a case with TAC, it could be a bug or limitation of the software.
Thanks Patrick,
i notice this when I use my coSpace ID associated to my profile when use WebRTC app.
Surely this cannot be a limitation.
Yeah, I don't know. Maybe WebRTC doesn't recognize that particular API command, but CMA does.
This has been fixed in CMS 2.3.1, see CSCvh71737.
 Hi Patrick,
Thanks for the update.
And thanks to Cisco !
