09-14-2004 12:33 PM - edited 03-13-2019 06:21 AM
Trying to force certain dial-peers to use a different codec. The following config we have setup in a lab. 2 MC3810's. 2 phones. Simulated WAN circuit using a serial cable between the 3810's with a DLCI of 231.
Router A:
dial-peer voice 1 pots
destination-pattern 10
port 1/1
dial-peer voice 2 pots
destination-pattern 11
dial-peer voice 101 vofr
destination-pattern 2.
session target Serial0 231
dial-peer voice 102 vofr
destination-pattern 20
codec g711ulaw
Router B:
port 1/1
destination-pattern 21
destination-pattern 1.
codec g711ulaw
When I try to call 10, it does not default to the codec I specified and vice-versa. It continues to use g729ar8. I verify this when I do a "show voice ports summary". Any ideas? Thanks in advance.
Dave
09-27-2004 06:16 AM
There is a conflict in the destination patterns of the vofr dial-peers. One is " 1." and another is "10" Hence the problem. They need to be very specific or different as it will take the longest match." 10 " matches with " 1. "also.
Additionally, you may like to verify your conifguration with the following document:
VoFR Encapsulation and Fragmentation
http://www.cisco.com/en/US/tech/tk652/tk692/technologies_tech_note09186a00800942e1.shtml
03-04-2005 02:50 PM
Dear davidoates
add this config to your Terminator Router :
voice class codec 10
codec preference 1 g729r8
codec preference 2 g723r63
codec preference 3 g723r53
voice class h323 205
codec bytes preferred local
voice-class codec 10
voice-class h323 205
Foad Godarzy (IT Manager)
