08-25-2005 01:54 PM - edited 03-13-2019 10:17 AM
I am having some issues with static and hissing on a PRI.
The Gateway is MGCP and I have checked the following:
1. "no mgcp vad"
2. Obviously there is no VOIP dial-peer with MGCP so no place to put "no vad"
3. Silence Suppression disabled on CCM side.
Another question I have, if you have "no vad" on a VOIP dial-peer on an h.323 gateway but you don't have "no comfort-noise" on the voice-port, will you still have issues?
08-31-2005 11:48 AM
I don't think you will have any major issues if you have "no vad" on a VOIP dial-peer on an h.323 gateway but you don't have "no comfort-noise" on the voice-port.
12-12-2005 08:22 AM
I hope that you were able to get this fixed, but if you weren't by any chance; go into the voice-port and add these two lines:
no vad
no comfort-noise
Jan
