取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
configuring phones and CUCM for SRTP
Hi All,
I am trying to find a way to configure Cisco IP phones to register with secure-SIP to CUCM and to use SRTP for media traffic. I found only one way to do so, which includes purchasing tokens from Cisco to generate CTL certificate and change the cluster security mode to mixed mode.
like the article below:
https://supportforums.cisco.com/document/73611/ip-phone-security-and-ctl-certificate-trust-list
I was wondering if there is another way to do so, without the tokens, like using a centralized CA server for the new certificates.
1 个已接受解答
已接受的解答
pkinane
If you have 10.0(1) or higher, you don't need the tokens. Otherwise you do need them.
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118893-technote-cucm-00.html
Please rate helpful content (i.e. videos, documents, comments). Also, please select the correct answer(s) if any comment(s) answer your question otherwise the questions remains on the support forums as unanswered
在原帖中查看解决方案
3 条回复3
pkinane
What version of CUCM?
pkinane
thank you for your answer.I am testing it in my lab setup currently. I will post the results once done the testing.
