08-31-2004 12:47 PM - edited 03-13-2019 06:11 AM
I have an ICS 7750 with a single CCM blade. I would like to add as MCS as a new publisher and make the current SPE a subscriber. I know that would be a complete rebuild, but are there any docs anywhere that tells me what I need to do to the ICS to pull this off?
09-08-2004 09:32 PM
Are you trying to keep your ICS or in the process of phasing it out with the MCS?
09-09-2004 12:05 PM
I have to keep it. The blade that is now the publihser will become the subscriber, and the new mcs will be the new publisher.
09-10-2004 07:26 AM
We are going through this now since the ICS has an EOL on it. We have been reading the following document. Hope this helps.
09-10-2004 08:37 AM
Thanks for the respnse. That doc does help, but Im still not sure if there are ICS specific things I need to do.
09-10-2004 10:10 AM
See your point. Since we are also going to have to keep the ICS for a little while, we will still have UNITY running on two SPE's, even after we move the CCM's off of it, we were told to be sure we do not remove the ICS Core software as well as leave the ICS agent software running on the other SPE blades remaining in the box. Other than that, regardless of where our CM's are located (same VLAN of course) their communication will remain the same since we will not be chaning any of information needed by the MRP's. What specifically are you concerned about with the ICS?
09-10-2004 10:22 AM
Im not worried about anything specific. I just have not hade very much luck with anything I do on the ICS
09-10-2004 10:37 AM
Tell me about it. I really liked the idea and intial functionallity of the ICS, but after a few upgrades and now moving to 4.0(1) CM, wow what a mistake.
For us we are just going to make sure that the system software for the ICS stays unchanged, this includes the SQL Server running on the primary SPE.
In any event good luck!
