COR OUTGOING on SRST appears to block internal calls as well??
palves
I want external users not to be able to reach extension 4002. However, I want internal users to be able to reach this extension. However, using the config below, it appears no one (internal or external) can reach extension 4002.
Can I make it so that only external users can't reach extension 4002?
dial-peer cor custom
name pstn
name internal
dial-peer cor list pstn
member pstn
dial-peer cor list internal
member internal
call-manager-fallback
max-conferences 4
ip source-address 192.168.5.1 port 2000
max-ephones 5
max-dn 12
dialplan-pattern 1 545321... extension-length 4
cor outgoing internal 1 4002
dial-peer voice 1 pots
corlist incoming pstn
incoming called-number .
direct-inward-dial
port 1/0:23
palves
No one run into this before??
You can add a default incoming cor list of internal so all IP phones will be able to see the internal cor list and call 4002.
max-conferences 4
max-ephones 5
max-dn 12
cor incoming internal default
HTH,
Michael
