Could anyone give help me in installing dmm 5.3 in UCS -SERIES SERVER
I am trying
to install DMM-5.3.0.244.isov in the UCS  B-series  server
i am getting the below error
Could anyone help.
Please give me the alias for DMM.
2 Accepted Solutions
So I do have the same iso image you are trying to use.  I think you may have an incorrect hardware configuration on your C210.  Is it an off the shelf C210 or was it purchased as a DMM?  I'm pretty sure DMM is only supported on a C210 that has hardware specd specifically for the DMM.  Basically it is an appliance.
Cisco Digital Media Manager 5.3.x on UCS C210 (DMM-SVR-C210-K9)
I don't think I can't help you from here.  You will have to contact TAC.
8 Replies 8
Mike Assel
Enthusiast
Enthusiast
DMM is not supported on the B series.
Hi Mike,
I have also tried with the c-series server, am getting the same error.
Please help.
Can you give alias for DMM.
http://www.cisco.com/en/US/partner/docs/video/digital_media_systems/5_x/5_3/dms/aai/administration/guide/intro.html
Supported Appliances
This document describes how to set up and administer the following Cisco Digital Media System (DMS) 5.2.x appliances:
Cisco Show and Share appliances:
Cisco Show and Share 5.3.x on MCS 7835-H3
Cisco Show and Share 5.3.x on WAVE-574
Cisco Show and Share 5.3.x on UCS C210 (SNS-SVR-C210EN-K9)
Cisco Show and Share 5.3.x and Cisco Show and Share Reports 5.2.2 on UCS C200 (SNS-SVR-C200WG-K9)
Cisco Digital Media Manager appliances:
Cisco Digital Media Manager 5.3.x on MCS 7835-H3
Which C series?
C210 series i have installed but getitng error
Thanks a lot.
WHere did you get the iso you are using?  I'm not familiar with that version.  Is this a fresh install or an upgrade?  Normally you have to upgrade from 5.2 to get to 5.3.  You can't do a fresh 5.3 install unless you have a special iso that someone from Cisco posted to you.
i have 2 doubts still
1. i have only ucs server which is not purchased as dmm, can i try  with DMM 5.4 VM image whether it will work.
2.
I need to implement Digital signage solution in my office workplace.
I have DMP 4400G and TV only , can I implement the solution without DMM,SNS,Stadium vision director.
Please suggest me your valuable inputs
Thanks a lot for your great support.
Rajesh
Recognize Your Peers
