How can I get the CTI Route Point description to show on an inbound call instead of or with the Caller Id? This is only needed for a few phones in the cluster so I can't change it on a Systemwide parameter. Call Manager version is 4.1(3).
I would create a Translation Pattern which overrides the CallerID only for those phones (Use CSS to restrict this)
Calling number 408 XXX XXXX
Hit GW (GW contains partition for TP)
TP modifies the CallerID ...?
//G
My problem is the same but I've not understand your suggestions. I try to modify the phone line configuration, translation pattern configuration but without outcome.
Any more informations?
Thanks in advance
Claudio
