328
Beginner
CUBE SIP DTMF Troubleshooting
Hi Experts!
Good day. Would like to ask what debug should I used to know if the cube was able to received any DTMF. I already used debug voip rtp session named event but no logs was displayed. Also is it possible to change the incoming payload type on the outgoing dial-peer?
Thank you so much in advance!
JP
Everyone's tags (1)
7 REPLIES 7
Highlighted
VIP Collaborator
Re: CUBE SIP DTMF Troubleshooting
Which DTMF type is configured on your SIP dial-peers? rtp-nte, sip-notify, sip-kpml?
Beginner
rtp-nte was configured on the dial-peer.
thanks,
JP
VIP Collaborator
With rtp-nte, that debug should have shown the DTMF as it flowed through. I don't have a good answer for that.
As for altering payload types, it absolutely can be done. You haven't provided your config so I can't make specific suggestions, but this document may help:
CUBE Configuration Guide: Dynamic Payload Type Interworking for DTMF and Codec Packets for SIP-to-SIP Calls
Maren
VIP Advisor
It's possible rtp-nte wasn't even negotiated. To see the DTMF negotiated for the call, you can use show call active voice | in PeerAddr|Dtmf
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
VIP Advisor
When you say "change the payload type", do you actually mean the PT header of the RTP packet?
E.g., RTP PT 101 to 100
Or do you mean change the DTMF method?
E.g., rtp-nte to sip-kpml
Either is possible, and in fact Maren already shared a link on how to do the former. The latter is done automatically by CUBE as a part of its DTMF interworking capabilities.
Anthony Holloway
Beginner
Hi Anthony!
Yes we would like to  change PT header of the RTP packet. For the current setup we were receiving 116 Payload from our SIP Provider but we were not able to change this Payload type to 101 using rtp payload-type nte 101 to the command on the outgoing dial-peer. Is transcoder needed?
Thank you so much!
JP
VIP Advisor
The topic of asymmetric payload types has been discussed pretty well here:
https://community.cisco.com/t5/ip-telephony-and-phones/cube-asymmetric-dtmf-inter-working/td-p/2905935
Anthony Holloway
Content for Community-Ad
August's Community Spotlight Awards
