514
Highlighted
CUBE SIP REFER with Telco
I have a customer that has two datacenters.  They want a SIP trunk into each datacenter from the same telco.  They want to be able to use the SIP Refer feature on a CUBE to redirect a call coming into one datacenter back to the telco and over to the second datacenter CUBE should there be a failure or full circuit.  My question is does CUBE support this?  No UCM is involved.  The CUBEs are connected to third party PBX.
Everyone's tags (1)
2 REPLIES 2
Beginner
Hi There, Yes this is
Hi There,
Yes this is possible , you can configure in the global level or a specific dial-peer, but pls chk the prerequisites:
  • To enable the Dynamic REFER Handling on the Cisco UBE feature, you must have Cisco IOS Release 15.2(1)T or a later release installed and running on your Cisco gateway.
  • Transcoding configuration is required on the Cisco UBE for midcall transcoder insertion, deletion, or modification during call transfers.
refer the below link for more info:
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/cube_sip/configuration/15-2mt/voi-cub-sip-dyn-refer-handling.html#GUID-2CA58270-E894-44E0-BF95-D891BC07D596
Beginner
Hi Murali,I have a query on
Hi Murali,
I have a query on SIP Reffer,
Is SIP REFER Transfer depends on Telco side, different carrier has different config on CUBE side?
i am planing to configure SIP REFER in one CUBE which has both incoming and outgoing traffic.
Thank you
Paddy
Content for Community-Ad
August's Community Spotlight Awards
